Whats wrong my suspension?!
Old May 31, 2005 | 10:24 PM
Revin9K's Avatar
Default Whats wrong my suspension?!
I just put on my 18" volk le37, and only the driver side is rubbing when i make turns. my car is lowered on tein stech. the front driver side is lower than the passenger side, what could be wrong and how do i fix this? (besides buying coilovers)
i could swear it was like that from the dealer....is it common for one side to be lower than the other?
btw the rear is even.
Old May 31, 2005 | 10:31 PM
MC21's Avatar
hmm, how heavy are you?
Old May 31, 2005 | 10:35 PM
Revin9K's Avatar
ok good point i guess...im 180.
but i measured when im outside the car, from fender to lip of rim is uneven on front. but same on back...
Old May 31, 2005 | 10:43 PM
superslows2k's Avatar
just checking, but did you double check if the springs are sitting in the perch? only thing i can think of right now that would be an easy fix
Old May 31, 2005 | 10:54 PM
Revin9K's Avatar
just checked, everything seems to fit fine.
could it be an alignment issue? its just a few mm's off. Just enough to rub ! =\
Old May 31, 2005 | 10:59 PM
MC21's Avatar
one last thing to check....reverse park at the spot your measured the gap and measure again. ground might not be flat.
rubbing on driverside when you are 180lbs is, I dont want to say, normal
Old May 31, 2005 | 11:03 PM
chrisboiii's Avatar
I have the same wheels with the same springs and I rub on the driver's side as well, but not just on regular turns, only if I turn extremely hard. Majority of the time it's on freeway dips so you should get it checked out if you are rubbing on normal turns. I am 180 also btw. Good luck.
Old May 31, 2005 | 11:05 PM
Revin9K's Avatar
even ground... when im not in the car...the left is lower than the right by about 0.5 cm.
Is it normal for one side to have a bigger gap? basically, do all s2000's come perfect from the factory?
Old Jun 1, 2005 | 08:32 AM
SpeedxRacer's Avatar
It should be even from the factory, how long have you had these springs on?
Old Jun 1, 2005 | 10:54 AM
JSR_AP2's Avatar
Every civic/integra I've owned and seen is "lop-sided" (one side lower than other). I wouldn't be surprised if that was the case w/ the S also. I rub on the driver's rear during hard turns or big dips/bumps at high speed and I'm on stock springs (my tires are a bit wide), but I never rub the pass's rear.
