wheel alignment ?
I'm currently dropped on tein s techs with ap2 wheels. I'm getting some uneven tire wear, would a wheel alignment fix this or do i need camber correction kits
Moving to the Wheel and Tire forum
Did you have an alignment done after you lowered it?
If not, definitely get a proper alignment. Not just toe at the local Mr. Tire, but a full alignment including toe, camber, and caster. If the shop can't get you back to the factory alignment settings, then yes, you might need a correction kit. |
| All times are GMT -8. The time now is 07:36 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
