Wheel/Tire Tutorial
Old Jan 21, 2004 | 05:19 PM
AustinS2k2003's Avatar
Default Wheel/Tire Tutorial
I am looking to understand more about selecting wheels /tires. I want to know offsets for 17", 18" and 19" wheels that will fit the S, as well as the tire size with the lowest profile for each. Thanks for the help!!!
Old Jan 21, 2004 | 08:28 PM
Tireguy's Avatar
HONDA S2000 CONVERTBLE 2 DOOR 2000-2003
OEM
F 16X6.5.....+55mm.....70.7mm hub bore
R 16X7.5.....+65mm.....64.1mm hub bore
5-114.3 BOLT PATTERN 12X1.5 LUG NUT w/19MM HEAD
WIDTH....................OFFSET ..........................WIDTH OF TIRE
FRONT
7.0........................+40/+45.............................205/215/225
7.5........................+40/+55.............................205/215/225
8.0........................+40/+55.............................205/215/225
REAR ONLY**DIFFERENT HUB BORES FROM FRONT TO REAR***
8.0........................+45/+55.............................245/255
8.5........................+50/+65.............................245/255/265
9.0........................+55/+65.............................255/265
9.5........................+60/+65.............................255/265
10.0......................+73/+75.............................275/285
COMMENTS:
+40MM OFFSET WITH AN 8-INCH WHEEL IS AT THE EDGE OF
THE FENDER WITH THE TIRE A 1/4 INCH OUTSIDE FENDER.
LOWERED VEHICLES MUST USE HIGHEST OFFSETS POSSIBLE.
Gbcrebel13
Jan 9, 2014 07:22 AM
jon o
Jan 6, 2011 06:38 AM
dthondatune
Apr 4, 2007 07:33 AM
Silver9k
Aug 19, 2004 02:00 PM
Shvitz2k
Mar 25, 2004 08:44 PM
