View Poll Results: Which wheels to go with?
TSW interlagos 17x9 square +63 ~17-18lbs each
16.67%
Enkei rpf1 17x8 +45 front 17x9 +45 rear ~16lbs each
16.67%
Wedsport SA-72R 17x10 +55 square ~20lbs each
66.67%
Voters: 6. You may not vote on this poll
Old Jan 7, 2024 | 10:10 PM
michaelnyden's Avatar
Default Which wheels to go with?
Which wheel should I go with?
TSW interlagos 17x9 +63 square ~17-18 lbs each
Enkei rpf1 17x8 +45 front 17x9 +45 rear ~16 lbs each
Wedsport sa-72r 17x10 +55 square ~20lbs each
All clear the brakes I have, my car is Suzuka blue with rolled fenders and -2.5 degrees negative camber, looking to not poke or stick out tons but a little is okay.
Old Jan 8, 2024 | 06:21 AM
yamahaSHO's Avatar
They are all decent options if they fit. I went with the Interlagos (and Nurburgring) due to brake fitment, though I still have to run a 3mm spacer. I really like the Interlagos and think they fit the car well. I use my Nurburgring as track wheels, which do not require the spacer for brake clearance... I think they look decent, but I like the Interlagos better.
Old Jan 8, 2024 | 11:53 AM
Manga_Spawn's Avatar
Site Moderator
If the fenders are rolled then option 2 or 3 is what I’d do. 17x10 all around with 255’s makes the steering pretty heavy but would be best for the track so depends how often that’ll be a factor.
Old Jan 8, 2024 | 01:44 PM
Bullwings's Avatar
Since you included the 17x10 +55 sa-72r, any reason why you're not cross shopping it against the 17x9.5 +47?
My vote goes to the SA-72R in either the 17x10 or 17x9.5 variety versus the other two options above.
Also, what's your intended use?
Old Jan 9, 2024 | 03:21 PM
ncrx's Avatar
how about apex 17x10's?
Old Jan 9, 2024 | 06:34 PM
Bullwings's Avatar
I completely forgot about that option, back when i bought my wheels the SA72r in 9.5", neither Titan7 nor Apex were options.
If I were to buy track wheels now (which is what my car is - 90% track), I would get the Apex in 17x10 +48. I think that those are the best bank for buck wheels and the sweet spot for fender/A-arm/upper-wheel-well clearance and being BBK compatible.
Old Jan 10, 2024 | 02:47 PM
ncrx's Avatar
yup, i originally got the weds sa72r 17x10's b/c it was really the only option at the time. they're pretty heavy, i got the apex 17x10's after and they do have better a arm clearance and are noticeably lighter for not much more dollars. also im not a huge fan of how the sa72r's look, but they're pretty cheap i guess.
xpj808
Dec 19, 2021 06:10 AM
