S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   why am i rubbing? (https://www.s2ki.com/forums/wheels-tires-56/why-am-i-rubbing-773747/)
g35s2000 Mar 15, 2010 10:15 PM
why am i rubbing?
Hi guys. So i have rims with 7.5' offset +48 front with 215s and 8.5' offset +55 rear with 235s. The fronts arent rubbing at all but on the rears, i get slight rub when making high speed turns or going over dips at a moderate speed. I am lowered to one finger gap all round with tein flex coilovers. According to the sticky, shouldn't I not be rubbing? thanx for the input
alpha318 Mar 15, 2010 11:29 PM
what are you rubbing on? bumper tab?
Mar48 Mar 16, 2010 01:00 AM
i rubbed with 18x9 +65..... but with a 265 tire.... I would add some camber if I were you
camuman Mar 16, 2010 05:07 AM
relocate the bumper tab and roll the fender. should go away then. i am not a fan of adding camber to alleviate rubbing. you should only add camber if you need it at the track. IMHO.
ZDan Mar 16, 2010 05:35 AM
I'm guessing you're on 235/45-17s, which are taller than stock.
You might actually be better off on 245/40s than on 235/45s.
Regarding camber, 2* - 2.5* I consider to be streetable enough, particularly if you don't run a lot of toe.
1nate7 Mar 16, 2010 05:37 AM
The sticky is for stock height and is just a guideline. There are a lot of variables in play. Do you have the correct tire diameter? I'd try bending the bumper tab slightly back, you probably don't need much work. If you are running stock alignment then go to UK spec, around -2 camber rear.
Mar48 Mar 16, 2010 11:26 AM
Personally I had 2.5 degrees and zero toe with the 265... If you do have 235/45 you should get those switched out and that should fix the problem like ZDan said
Tripleblackap1 Mar 16, 2010 12:01 PM
:iagree: I would try -1 front camber and -2 rear camber, or UK camber specs. Very streetable. Also ZDan is right, you have the wrong size tire. Try the 245/40 like he suggested.
camuman Mar 17, 2010 06:30 AM
im gonna say it again with my experiences as the proof in da puddin
i run
18*8 +50 225-40-18
18*9.5 +55 275-35-18
rolled rear fenders/relocated rear bumper tab/dropped at least an inch on coilovers/STOCK ALIGNMENT SPECS 0F/-1R camber
NO RUBBING even with my 190 lb fat ass and my buddies 245lb fat ass in the car at the same time.
SOOOOOOOO.......do what you want, but with s2k friendly offsets/s2k friendly size tires, i dont see at all why you shluld run UK SPEC'd camber.
UK SPEC'd camber ate my advan ao48s prematurely :( blah to that...unless you track your car, then by all means add camber.
for u, stock ap2 size tires, maybe go stock CR size in the rear, roll the rear fender, relocate that rear bumper tab<it sounds worse then it is, its friggin easy> and you should be fine.
i 100% feel u are rubbing on the rear bumper tab. i bet its even bent up slightly from all the rubbing.
Tripleblackap1 Mar 17, 2010 09:02 AM
I have BFG NT's 215/255, +50 and +55, -1 & -2 camber. I have 7000 miles NO uneven wear. Sorry it ate your advans, but it has been working great for me.
I totally agree with going with high offsets. +50, and +55 work great on stock fenders.
© 2026 MH Sub I, LLC dba Internet Brands
