Widest Tires for 18X9 +62 rims
Whats up fellows, what is the widest tires you can put on a 18X9 +62 rims? Currently i have 255-35-18 right now. Can i put 265-35? Thanks....
any input?? :thumbup:
you should be able to stick 265s on there w/ no problem.
yep i agree with obseriouso however you need to know what tire you will be using as well. not all tires are the same size even if they are all 265's i have 18x9s now and the 255s in the fk451 and i know i can run a bigger rear. i also noticed the tire itself is a bit smaller compared to other 255s as well
im running 265/35/18 offset is +63 i rub very little .es100 btw
thanks guys..
