S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   Will it fit? (https://www.s2ki.com/forums/wheels-tires-56/will-fit-813043/)
dennisnguyen Aug 29, 2010 11:36 AM
Will it fit?
Found a pretty good deal on some wheels, wondering if they will fit.
specs:
18x7.5
+42 offset
is 7.5 too small for all around?
Thanks!!
s2sik Aug 29, 2010 11:49 AM
yes they will fit, but typically you probably want at least a 8.5 in the rear
JDMQuip Aug 29, 2010 12:08 PM
I'd pass on those wheels. But to answer your question, yes it will fit.
Jim@tirerack Aug 30, 2010 02:04 PM
Depending on the tire you use. The 42mm offset is low and may have some issues on the front with a 225/45R17. I agree that a wider rear wheel is prefered.
© 2026 MH Sub I, LLC dba Internet Brands
