will this fit? work cr kai
Old Nov 8, 2011 | 09:48 PM
bj84's Avatar
Default will this fit? work cr kai
Hi
I'd like to buy 18 work cr kai front 7,5 ofset 48 and rear 8,5 offset 43 and tires 215 and 245. I've ground control suspension (mix koni and eibach). My question will this fit without roling fenders?
thanks
Old Nov 9, 2011 | 09:02 AM
bj84's Avatar
Anyone ?
Old Nov 9, 2011 | 09:46 AM
deepbluejh's Avatar
It will fit, but it will rub the outer part of the tire sidewall under large bumps (in the back).
Old Nov 9, 2011 | 09:59 AM
ryuken's Avatar
Your front should be fine. I agree with deepblue on the rear.
Old Nov 9, 2011 | 10:19 AM
bj84's Avatar
Thank you for anawer. What should I do with the rear ? Roling litle fenders or mayby tires 245/35 fit better then 245/40 ? Thank you for yours advise.
Old Nov 9, 2011 | 10:23 AM
ungucpho's Avatar
rears should be 245/35 regardless. you should be able to fit it with a roll, bumper tab relocation and a little camber
Old Nov 9, 2011 | 10:37 AM
bj84's Avatar
Ok menas front should fit perfect with tires 215/35/18 and rear with 245/35/18 Bumber tab relocation and litle camber ?
Old Nov 9, 2011 | 04:32 PM
ryuken's Avatar
The front should be 215/40/18 and the rear 245/35/18 if you want the outside diameter to be the same as OEM specs
Old Nov 10, 2011 | 01:18 AM
bj84's Avatar
Yes thank a lot for advise !!!
Vi3tbo1209
Mar 16, 2011 11:17 AM
FTMFW
Dec 2, 2009 09:25 AM
lzybum
Jun 18, 2009 05:18 PM
JoeyBalls
Jan 30, 2009 02:13 AM
flipnrr
Jul 23, 2007 10:57 AM
