Will these EVO 9 BBS fit?
Old Jul 27, 2009 | 08:07 AM
buzz944's Avatar
Default Will these EVO 9 BBS fit?
as the title says will these EVO 9 BBS fit the S2k?
any fender work needed?
here the wheel photoshoped on the car
Old Jul 27, 2009 | 08:32 AM
1nate7's Avatar
They are 8" +38, will need fender work in the front for sure. Also, the wheel bore is 67.1mm so you have to machine them to fit over the front hub.
Old Jul 27, 2009 | 08:48 AM
buzz944's Avatar
in other words: i should ditch right??
thnx for you relpy
Old Jul 27, 2009 | 10:00 AM
JP Money's Avatar
If you like the style, you can get the OZ Ultraleggera, its very similar.
Old Jul 27, 2009 | 12:45 PM
buzz944's Avatar
yea i know but my friend is selling his wheels & tires really cheap
Old Jul 27, 2009 | 01:02 PM
Terror's Avatar
If you want them, get them. I'm sure you can find a wheel shop that can bore out the hub size to fit an S2000.
Old Jul 27, 2009 | 01:09 PM
s2k dre's Avatar
The rear isnt gonna be that aggresive.
Old Sep 5, 2009 | 10:11 AM
Crab Rangoon's Avatar
Sorry to bump this back from the dead, but I'm just surprised that nobody's done this before. I've seen more than one S2000 running the BBS off the STI, and they have an even higher offset than these all around.
Nobody has pics of these actually mounted up on an S2K?
Old Sep 7, 2009 | 09:16 AM
03evolution's Avatar
I mounted my enkei evo ix wheels on my s2000 and hub size is a bit different. plus all stock evo wheels are 17x8 +30 so it stuck outside the front fenders a bit since the offset is a bit low. In my opinion just go with another wheels set up.
Old Sep 7, 2009 | 07:06 PM
ASM Stook's Avatar
Just run a spacer on the rear if they aren't aggresive enough for your taste back there.
