will this tire size work?
will this work with a 1 inch drop (espelir springs) / KONI yellows.
P215/50/17 front and P245/45/17 rear. i need a little more height for a lip to clear my driveway. will ABS be affected? will VSA be affected? any negative affects basically?
factory tire is a 215/45/17 which will be a taller tire then this, What size are you running now?
I had 215/40/17s on a set of used wheels I bought, it will work, but is really small for the S2000
Here is a picture with the 215/40/17s
Here is what it looks like with 215/45/17s sits higher and will fit.
Originally Posted by hey_i'm_new,May 27 2007, 09:40 PM
i need at least another inch of clearance for my driveway. can i put a 45 on my rear and 50 on my front?
Originally Posted by AP2,May 27 2007, 10:08 PM
you can do it, but the handling will decrease a little...
i'm hoping a P215/50/17 front and P245/45/17 rear will give me an .5 of an inch.
Originally Posted by mic_crispy,May 29 2007, 10:39 AM
How bad does it scrape? Is it metal, or just plastic?
