work emotion vs work emotion CR
Old Nov 13, 2005 | 08:28 PM
asu_lee's Avatar
Default work emotion vs work emotion CR
So what is the difference? I know the emotion is forged. Is the CR?
What offsets for a 04?
Anyone know where I can still get emotions?(not cr)
-Lee
Old Nov 13, 2005 | 10:37 PM
903@AP1's Avatar
I also want to know the offset for my 00' S2K...
want to use 215 or 225 / 45 /17 front tire
& 235 / 245 / 40 /17 rear tire .....
original suspension with low down spring only.
Any suggestion ? please help !
Old Nov 14, 2005 | 09:47 PM
SSX's Avatar
SSX
The Work Emotion is forged. Therefore the weights are approx 15 lbs front and 16 lbs rear. I believe the Emotion CR is cast, not sure about the weights though, probably closer to 18 and 19 lbs? Also the Work Emotion comes standard with center caps, while the other Emotion variations (CR Kai) do not use center caps, and have a slightly different design around the center cap/lug nuts.
The Emotion CR has different offsets - at least for the 17" The CR's are sized: 17x7 and 17x8 with 47 offsets all the way around. The forged Emotions were available as a 17x7.5 (48 or 53 offset) and 17x8.5 (59 offset).
I'm running the forged Emotion's 17x7.5 (48 offset) and 17x8.5 (59 offset) with Honda OE Bridgestone RE050's - 215/45 and 245/40. I'm lowered one inch on Spoon Progessive springs over stock shocks. No rubbing issues at all.
Old Nov 15, 2005 | 06:06 AM
G127's Avatar
SSX, your wheels look great. Great offsets/fitment.
Old Nov 15, 2005 | 06:38 AM
papa5murf's Avatar
you can also go with 17x7 +42 up front for the bbk guys and use a 6mm spacer....
Old Nov 15, 2005 | 01:15 PM
asu_lee's Avatar
Thanks everyone for the responses? Where can I get a set of forged Emotions?
SSX, Great looking rims and nice offsets!
-Lee
Old Nov 15, 2005 | 02:40 PM
papa5murf's Avatar
i don't think you can get them.. they are hard to find/get ahold of
Old Nov 15, 2005 | 03:09 PM
specialque's Avatar
I have a set i *might* be willing to part with....
17x7.5 +40 and 17x8.5 +59 in bright silver (looks much like sebring silver), They are made for BBKs, I'm lowered on KW Variant 3's a little more than an inch, and I've never rubbed or hit the fender.
Old Nov 15, 2005 | 03:11 PM
specialque's Avatar
asu_lee,
I'm sorry to answer you question, you can get them from TodaRacing Directly. I would give them a call. There aren't too many of these wheels floating around anymore.
Regards,
Luke
Old Nov 15, 2005 | 03:53 PM
S2kWLA's Avatar
wow for some reason i thought the forged Emotion's were discountiinued?? i kept hearing that.. hum
specialque how long ago did you get these?
