Work emotions?
Hey I've just got a set of work emotions and was wondering what tire size would fit with varis or asm front fenders and asm rear fender flares.
My rims are: front 17/8+47 offset
Rears are 17/9+44 offset
Will 245/45/17 and 275/40/17's fit ok?
Or, 235/40/17 and 255/40/17's
What do you guys think? Any help would be greatly appreciated.
Originally Posted by silentdancer,Apr 8 2007, 03:41 PM
how much wider are the front fenders/rear over fenders?
The rear overfenders are about 1 inch
The 245/45/17 and 275/40/17' combo has virtually the same circumference. I would work around that setup.
Looks like you will need the ASM front fenders to pull that off though.
James
James
Originally Posted by 161MPHTOPSPDS2K,Apr 9 2007, 08:19 AM
asm front fenders are 25mm, varis 10mm
Since the ASM Rear over fenders and front fenders widens up an extra "inch" more due to the extra 25mm, your best bet is to run the:
235/255 combo
265 is do-able, but you have to ensure that you actually cut the rear fender to ensure maxium clearnace to run the ASM over fender properly and run slight negative camber. IMO I'd run a 265
Originally Posted by OBSeRiouso,Apr 9 2007, 06:25 PM
245/45/17 and 275/40/17' are a tad bit too aggressive for the that set up.
235/255 combo
235/255 combo
Falken azenis don't come in a 265 in 17's.
thanks guys!
Originally Posted by 161MPHTOPSPDS2K,Apr 9 2007, 09:45 PM
Thanks for the insight
I've been thinking about cutting the rear fender for the asm overfenders to fit the 275's but yeah the 235/ 255 combo is for surte the safest.
thanks guys!
thanks guys!
Show pics! when you get the chance
ej2
Oct 24, 2012 03:26 PM
