S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   Work VS-XX (https://www.s2ki.com/forums/wheels-tires-56/work-vs-xx-483133/)
Gatsbee13 Apr 23, 2007 08:14 PM
Work VS-XX
Hey guys.. found a set of Work VS-XX wheels. The size is 5Hx114.3 @ 17x7.5 +41 17x8 +41. Will these fit my stock '03 without rolling or shaving fenders? Also, since the rears are 17x8, which is .5 larger than the front, should i run bigger tires for the rear? I know the rear should be atleast 1 inch wider. Thanks -david
velocityracer Apr 24, 2007 10:48 AM
without rolling or shaving the fenders, will it fit? NO it willNOT fit.......yes when you have a staggered rim you should stagger the tires .......
If you ran 215 front 225 rear with rolled fenders and lots of negative camber this MIGHT work!
S2KrNBRuIn Apr 24, 2007 11:03 AM
Well, I used to have a set of Pro N1's and they were 17x7.5 +45mm and 17x8 +38mm.....they fit like a charm without fender rolling not to mention I was dropped like 1.5inches. I was running 225/40/17 F and 235/40/17 in the rears. You have to think of it this way: Every 0.5 you increase in width you have to have approximately +10mm in offset so that you don't have to roll the fenders. For example most people get around a +50ish offset for the rear when the width is 8.5...for 9inch rears you'll need approximately a +60mm. Therefore, if you run a 8 in the rear +41 should be ok as long as you don't get the wrong profile tire. Oh but I'm not too sure about the +41 in the front....
Here's a pic of my old setup
https://cimg5.ibsrv.net/gimg/www.s2k...d6bc1befd4.jpg
silentdancer Apr 24, 2007 06:43 PM
it will work, 215/235
© 2026 MH Sub I, LLC dba Internet Brands
