Is it worth even trying to do?
I've got a set of Gram Light 57F's from my last ride. They're 18x8.5 with a 45mm offset.
With the addition of wheel adapters would these even be close to fitting right? I'm running AP2 wheels right now lowered on the TEIN S-Tech Springs. If these could fit, what size spacers would you recommend? Thanks! Nate |
spacers would create an even more aggressive offset. these could work, but you have to run staggered tire sizes and roll/pull your fenders
if all else fails.. sell them and get a new set of wheels
I've had them up for sale for a while.....just a thought
You also have to make sure about the center bore. Your S2K is larger in the front. If centering rings are not available you are going to have a vibration.
| All times are GMT -8. The time now is 03:04 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
