Yokohama size
Old Apr 16, 2006 | 08:54 PM
Jakup's Avatar
Default Yokohama size
When I bought my car, the previous owner had Yokohama ABS dB S2 tires installed. The problem is, the rears are 225s. They are about half worn out, and I want the correct 245 size anyway, so I'd like to replace the rears with the same tire, just the correct size.
On Tire Rack, there are no 245/45/16 available for this tire. The closest I see is 245/50/16. Should I go with this size?
Here's a link to the size chart...http://www.tirerack.com/tires/Sizes.jsp?ma...model=AVS+dB+S2
Old Apr 16, 2006 | 10:00 PM
xviper's Avatar
A 245/50/16 tire will have a slightly taller sidewall. It will be about 0.7" bigger in diameter, so your speedo will be out by 2.8% and your gearing will be like having 4.00 FD.
Old Apr 17, 2006 | 07:03 AM
Jim@tirerack's Avatar
Former Sponsor
It would also effect the anti lock brakes. I woul stay with the 225/50R16 in the rear with the matching tires.
If I can help let me know.
Thank you,
Old Apr 17, 2006 | 08:49 AM
Ragingazn's Avatar
go with the avs es100's they have the 245/45/16 size you are looking for.. not bad for the price either
Old Apr 17, 2006 | 10:00 AM
Jakup's Avatar
So it looks like I have to buy 4 new tires to get the correct size (to avoid mis-matching front/rear).
How about the Bridgestone RE750? Will these grip better than the Yokohama's I currently have? And would the correct size be Front-205/55/16 / Rear-245/45/16
Old Apr 17, 2006 | 10:11 AM
Jaydem's Avatar
Jakup, just get a set of 17' Volks with ADVAN Neova AD07 and youll be good to go!!
Jakub
Old Apr 17, 2006 | 10:19 AM
Jakup's Avatar
Jakub
I'm sure I would be. Send some money over this way and I'll be glad to take that suggestion
Old Apr 17, 2006 | 05:44 PM
Jakup's Avatar
So how are the Bridgestone RE750's on dry grip, and how are they on tread life? Also, is the proper size Front-205/55/16 / Rear-245/45/16 ? I've read a few people running 225 for the front, is there a benefit to this?
Old Apr 18, 2006 | 05:24 AM
Former Sponsor
The Bridgestone RE750 would be a better wet and dry handling tire than the Yoko's you have had. They are also the longest wearing performance tire that I have seen. I have had them on my own car for two years and they still look new. They are also a quiet smooth riding tire.
I also do have a 50.00 rebate on a set of four tires till 05/06. If I can help let me know.
Former Sponsor
You can run either the 225/50R16 front of 205/55R16 front. The 205/55R16 looks a little better but the 225/50R16 will handle better.
