10.5" rear fitment
10.5" rear fitment
Buying this wheel set up:
18x8 +40
18x10.5 +70
1. Will I need to do any modifications to make it fit? (currently stock)
2. Will I need to do any modifications once lowered on coils?
3. Pros and cons on this set up?
Thank you
18x8 +40
18x10.5 +70
Thank you
A lot of it depends on tire size. 245/35, 285/30 would probably be your best option but will require a fender roll regardless of ride height.
2.5" of stagger causes a few minor issues. 225/40 would be a good tire for the 8" front but is best paired with a 255/35 rear which would be very stretched on a 10.5" wheel. Also, compared to stock the front (+27mm) is slightly more aggressive than the rear (+20mm).
my best advice is to buy wider fronts. At least 9"s +45 or higher
Compared to a popular sized 17x9 +45, a 10.5 +70 wheel will sit about 6mm inboard. Outside clearance should be good with a roll and tab relocation just to be safe. I don't know how close the inside of the wheel will get to suspension parts though.
Not needed for the rear with 285/30 if you run the appropriate alignment, but the front will. If you could find even a +45 for front you could get around it with decent camber.
Site Moderator
Not if he is lowered. Which plans on doing. It will grab the fender eventually.
What is your area? Have you asked in your local subforum on here who people go to for fender rolls?
