17 Inch TE37 SAGA Release! S2000 Sizings Available *New 2017 Kamispeed*
#61
The 9.5 +56 TE37 SL fit a BBK with no spacer. With only a 2 mm difference these should clear pretty much the same, unless the back of the face is a different shape on the Saga than it is on the SL.
#62
Shout out to Josh at KamiSpeed for these amazing wheels. The color looks fantastic and is way better in person than pics. Plus the etched logos are a nice improvement from stickers. Josh was great to work with and provided updates on my order. Less than 24 hours to my door from time of shipment.
Thanks Josh.
Thanks Josh.
#64
Would running 17x9.5 +58 up front be an issue with most driving conditions? Wouldn't running 17x9.5 +58 be roughly equivalent to running 17x9 +64? I've heard of people running TE37's in 17x9 +65 for track use but I don't know if they had to use spacers. Would rubbing only occur at close to full lock? I'm really interested in using these 17x9.5's in a squared setup because fender modifications would be minimal. Also, have you found out if these will clear a Stoptech BBK? Any info would be appreciated. Thanks!
#65
#66
Thanks Josh.
Thanks Josh.
Quick question, which size wheels did you get and are those the flat or raised centercaps?
I've heard of some people.having problems work the flat center caps fitting with earlier te37's
#68
17x9+61. The caps are slightly raised. They are not flat. I will take a pic and post.
#70
I remember with earlier te37's/ce28 there were issues with flat caps fitting.
