17x8 Front and Rear with staggered Tires?
Picked up some SSR GTX01 17x8 +45 Front and Rear. The deal was so good, I couldn’t pass on it. I finally killed the tires on my AP2, and it’s time to wrap the SSRs. I’ve read a lot about what I should wrap the wheels with, and I’m still confused on what would work best. Option 1: F-225/45/17 R-245/40/17 Option 2: F-245/40/17 R-245/40/17 17x8 +45 Front and Rear, any problems with these wheels fitting? Would their be any problem with these tires sized on 17x8+45 wheels? Autocross use mainly 2006 S2000, Spoon Springs(1”drop) New to S2000s, thank you in advance for your help. https://cimg5.ibsrv.net/gimg/www.s2k...f27145557.jpeg https://cimg6.ibsrv.net/gimg/www.s2k...33ff2b260.jpeg |
I mean it’s not ideal since you are putting a narrower wheel in the rear and a wider wheel in the front option 1 would at least keep the car feeling somewhat close to stock though I’d do oem stagger 215 front and 245 rear to keep that even more in line. Option 2 is wrong in so many ways I have to assume they are typos. You can’t run a 16 inch tire on a 17 inch wheel. The aspect ration is wrong. If you were trying to go for 245 squares then it would be a 245/40/17 on all the wheels. |
Can you run those offsets without rubbing?
^^ seen how high it is !!
Not sure if Tire Rack is a good source for this, but they offer two wheels options with the same wheels specs. https://cimg1.ibsrv.net/gimg/www.s2k...a92758cf33.pnghttps://cimg2.ibsrv.net/gimg/www.s2k...4c518fb8ae.png |
Ive recent seen the same thing with them. Im not sure how much that can be trusted.
You have two use cases:
1. Street driving 2. Autocross Which one do you want to optimize for? If it's street, go with option 1 as you'll have slightly better steering feel and plenty of grip for just about any safe driving. If it's autocross, then go with option 2 to reduce understeer at the limit. When I switched to a square setup for the track, I was really worried that, based on the many comments here about how loose the S2000 is, that I'd be spinning off the track. In reality, the wider front tires gave a bit more cornering grip and significantly improved braking. Beyond that, there's very little difference, save a slightly more vague steering feel when driving to/from the events on the street from the wider front tires. So like I said, it's really up to you to decide which use case is the one you want to optimize. |
So are you saying a 17x8 48 offset will work on a street driven car with no issues?
Originally Posted by DanielB
(Post 24474911)
1. Street driving 2. Autocross Which one do you want to optimize for? If it's street, go with option 1 as you'll have slightly better steering feel and plenty of grip for just about any safe driving. If it's autocross, then go with option 2 to reduce understeer at the limit. When I switched to a square setup for the track, I was really worried that, based on the many comments here about how loose the S2000 is, that I'd be spinning off the track. In reality, the wider front tires gave a bit more cornering grip and significantly improved braking. Beyond that, there's very little difference, save a slightly more vague steering feel when driving to/from the events on the street from the wider front tires. So like I said, it's really up to you to decide which use case is the one you want to optimize. If Option 1 does not require to roll my fenders or much extra work I rather go with that. So would that work? if Option 1 requires rolling fenders, then I might as well go with Option 2 right? thank you for all the help so far! |
