17x8 Front and Rear with staggered Tires?
Picked up some SSR GTX01 17x8 +45 Front and Rear. The deal was so good, I couldn’t pass on it. I finally killed the tires on my AP2, and it’s time to wrap the SSRs. I’ve read a lot about what I should wrap the wheels with, and I’m still confused on what would work best.
Option 1:
F-225/45/17 R-245/40/17
Option 2:
F-245/40/17 R-245/40/17
17x8 +45 Front and Rear, any problems with these wheels fitting?
Would their be any problem with these tires sized on 17x8+45 wheels?
Autocross use mainly
2006 S2000, Spoon Springs(1”drop)
New to S2000s, thank you in advance for your help.
Option 1:
Option 2:
Site Moderator
I mean it’s not ideal since you are putting a narrower wheel in the rear and a wider wheel in the front option 1 would at least keep the car feeling somewhat close to stock though I’d do oem stagger 215 front and 245 rear to keep that even more in line. Option 2 is wrong in so many ways I have to assume they are typos. You can’t run a 16 inch tire on a 17 inch wheel. The aspect ration is wrong. If you were trying to go for 245 squares then it would be a 245/40/17 on all the wheels.
^^ seen how high it is !!
You have two use cases:
1. Street driving
2. Autocross
Which one do you want to optimize for? If it's street, go with option 1 as you'll have slightly better steering feel and plenty of grip for just about any safe driving. If it's autocross, then go with option 2 to reduce understeer at the limit. When I switched to a square setup for the track, I was really worried that, based on the many comments here about how loose the S2000 is, that I'd be spinning off the track. In reality, the wider front tires gave a bit more cornering grip and significantly improved braking. Beyond that, there's very little difference, save a slightly more vague steering feel when driving to/from the events on the street from the wider front tires. So like I said, it's really up to you to decide which use case is the one you want to optimize.
1. Street driving
2. Autocross
1. Street driving
2. Autocross
1. Street driving
2. Autocross
If Option 1 does not require to roll my fenders or much extra work I rather go with that. So would that work?
if Option 1 requires rolling fenders, then I might as well go with Option 2 right?
thank you for all the help so far!
estewkay_frankenstein
06-03-2013 10:28 PM
PsychoBen
Member S2000 Classifieds and For Sale
01-06-2004 06:25 AM
