18" wheel offset question
Old 04-19-2006, 09:00 PM
autophiliac's Avatar
Default 18" wheel offset question
Wheel experts,
I am interested in purchasing a set of wheels with the following specifications:
18 x 8 +52
18 x 9.5 +53
I was wondering if these will work without affecting the turning radius and rubbing issues.
The tire choices are f215 40r18/ r255 35r18.
Thanks in advance
Old 04-19-2006, 11:09 PM
gotswap's Avatar
https://www.s2ki.com/forums/index.php?showtopic=342793
You might find the answers you are looking for.
Old 04-20-2006, 12:08 AM
Thanks gotswap. Just tried the calculator and it looks the rear would be really tight.
BTW, nice wheels. Just curious what are your wheel specs?
Old 04-20-2006, 04:28 AM
Former Sponsor
Jim@tirerack's Avatar
You could make the 255/35R18 work but you would be better with the 245/35R18.
Old 04-20-2006, 07:22 AM
gotswap's Avatar
18x7.5 +45 w/225's
18x9 +51 w/255
They rubbed in the rear under very hard cornering.
Old 04-20-2006, 10:03 AM
Thanks Jim and gotswap for the feedback.
So the offsets for the front and back sould be fine with the tire recommendations: 215/245?
My S2K is lowered 1.25" all around.
I used the "calculator" and the rears will be pushed out almost an inch.
For the front, I just want to make sure they will clear without issues (+52 offset on 8").
I just wanted to get as much experienced feedback before purchasing the wheels.
Don't want to make the mistake again of running bad offsets.
Thanks!
Old 04-20-2006, 06:23 PM
RobZ's Avatar
My friend has 18X8 +50 with 225/40/18 and 18X9.5 +55 with 255/35/18. These are the same size tires recommended on Tire Rack for the wheels in these offsets, also on Tire Rack.
Old 04-20-2006, 07:02 PM
Bassem's Avatar
My rear 9.5s came with a 73mm offset. I would personally look for a higher offset, although a lot of folks seem to have no issues. Looks and fits pretty nice, no rubbing with 265s.
Bassem
xyster
06-11-2007 09:23 PM
racerfan
08-01-2006 12:16 PM
brianc555
04-27-2006 07:56 AM
Casas
07-08-2003 06:19 PM
mlgomez
05-04-2003 08:58 AM
Quick Reply: 18" wheel offset question
