18x8 +20 fitment issue?
Old 01-30-2013, 09:20 AM
Myth21's Avatar
Default 18x8 +20 fitment issue?
I have a friend that's selling a set of 18x8+20 TSWs
I am lowered on Buddy Club coils, I don't mind raising it a bit but how can I get this to fit? And what are the best tire sizes to go with it? I don't want any clipping.
Old 01-30-2013, 09:28 AM
1nate7's Avatar
Won't fit without fender work, negative camber, and stretched tires. I'd say look for something else.
Old 01-30-2013, 09:32 AM
Site Moderator
Manga_Spawn's Avatar
I can tell you have just done a HUGE amount of research and reading on your own. I am sure you read the wheel fitment faq and have read many threads about what other people are running on their car. And since you did that you somehow still needed to ask about these wheels so I will answer your question.
Roll the absolute hell out of your fenders, run 235's all the way around and run 2.5-3 degrees of camber. Even if you do all of this it is not going to be easy and you will still have the risk of it looking like ass and damaging your fenders. Just to clarify most people run the 9 inch wide versions of this wheel with a +60 or higher offset.
Also instead of asking us if he is your friend why not just test fit them on the car? That would answer your question pretty fast.
Old 01-30-2013, 09:34 AM
s2000Junky's Avatar
It will look horible, dont do it. Nothing worse then seeing some skinny ass wheels/tires, half of which are sticking out beyond the fenders. Swamp buggy FTL
Old 01-30-2013, 09:40 AM
Myth21's Avatar
Thanks guys, I figured lol....was hoping there would be some hope lol
Old 01-30-2013, 09:56 AM
s2000Junky's Avatar
You would need a lot more then hope
Old 01-30-2013, 11:08 AM
Myth21's Avatar
Guys, new direction:
say if I want to pick up a set of cheap Enkei's 17x7 and 8 +45 on both. What's the recommended size on tires for them? Tirerack says 205/50 and 225/45..which sounds a little weak imo..
Old 01-30-2013, 11:15 AM
Site Moderator
OEM Ap2 wheels are 17x7 front 17x8.5 rear. Look for wheels that are at least this width that way you can actually run a 245 or 255 tire in the rear.
On the ones you listed you can run a 215/45 front and a 235/40 rear. You might be able to cram a 245/40 on the rear but it would be better on an 8.5 inch wheel.
Old 01-30-2013, 12:28 PM
Myth21's Avatar
I'm having a hard time finding an affordable set for around $6-700 that are available in 17x7-8.5 or 9.
Old 01-30-2013, 12:52 PM
Myth21's Avatar
If I roll with 18x8/18x9 +40 what's a good tire size closest to stock? Sorry guys I suck at converting wheel specs.
Quick Reply: 18x8 +20 fitment issue?
