245/17/40 in the front
Just how bad will it be if I put 245/40/17 tires on the front 7 inch wheel for an AP2, I really can't stand the way the skinny 215's make the car look.
Want to run a square stance. Has anyone done this before? I don't really track my car just mostly casual highway driving, no harsh turns.
Inputs appreciated.
Inputs appreciated.
Site Moderator
It won't be good. A 225 would be a better choice. If you want a square setup but 2 more rear wheels and run a 5mm spacer to clear the hub. Then you can run a 245 in the front.
245s are gonna look fuggly and stuffed onto the rim. Don't do it man. If you wanna run square find a set of rear ap2 wheels for sale and have them bored out to clear the front hub. Then run 245s or even 255s all the way around.
Be aware that wider front tires will negatively affect steering feel on turn in. Also square setup will be more oversteer biased than the staggered setup you have now.
A lot of people here might suggest you bought the wrong car. You admittedly don't utilize its handling capabilities, and are more concerned about appearance of performance than actual performance. But its your car. Underutilize it as you see fit.
Not only will it look fuggly, it's not safe.
The car has staggered tire sizes for performance and handling -- not ricer stanced cosmetic reasons. The car understeers with the 215mm front tires and that will be acerbated with wider tires. Yeah, you can tune some of this out of the suspension. Do you know how?
-- Chuck
-- Chuck
