255 Square Stock fenders
So my .02, you can run 255 square with unrolled fenders and not touch anything, even if lowered a little. I did this for 3 years running 17x9 +60 Enkei PF01SS on all four corners, and lowered about an inch on Tien S Tech Springs... so it is possible.
Now for the wheels you are looking to run, I think you will have some rubbing on the street if it is at all lowered on the front fenders, and you may catch a fender when turning into a driveway unless you are crawling along. I would recommend you roll your front fenders, and dial in some negative camber. Rear fenders should be fine. Also the appropriate tire (as others mentioned) will be 255/35/R18's for your setup.
beefystud
10-15-2018 10:34 AM
