ASM Front Fender + Stock Rears Fitment Question
No balls to cut my rears yet, so trying to keep the OEM body lines intact. Would I be able to fit a 17x9.5 +35 all around? Or would a +38 be more doable in the rear.
Probably with -3 camber in the rear to prevent rubbing. They're already rolled flat and tabs are relocated. I'm not too worried about the fronts since
They can go as low as 9.5" +25, but I want to meet somwhere in the middle so I don't have to cut my rears up.
^^^ Yeah 5mm is a big difference when your running these range of specs. Fitment gets pretty finite. Consider another 5mm reduced outer clearance when moving from a 245 to 255 IF you can count on manufacture consistency, which you cant. Anymore then -2 camber on the street is pretty pointless really and performance overall is decreased the more negative you go from there to accommodate wheel and tires that dont fit. I would not choose a wheel and tire spec that forces you to run -3 or more camber to not rub.
Plan B is going to a 18x9.5+45 and run a 2-5mm spacer on street and no spacer for track to prevent rubbing. But that would require extended studs and the whole 9 yards. Don't want to do it if I don't have to.
So a little fender massaging might be necessary when I run a 255. I'm thinking about getting SPC ball joints, but not gonna go above -3 camber. I want to stay functional for track/street purposes.
17x9 +45 is the flushest setup for the oem fenders with pull+tab relocate. I'm using this setup with -2.6 camber and J's RCA. I still rub under full compression.
