Best spacers
Any generic 3mm spacer should work fine because you will just reuse stock studs and there should be enough of the hub still exposed for a hubcentric fitment. H&R makes a quality spacer if you are looking for the bolt on kind, just make sure to get the right hub size depending on front or rear (70mm/64mm).
Sent from my SPH-L710 using Tapatalk 2
