Best Tire Choice for AP1 running OEM 17s in New England weather?
Just curious: Are 17x9 wheels gonna fit all around? OEMs are 7" and 8.5" (F/R)? 215mm tire on a 9" rim?
Beware of TW ratings, they're manipulated by tire manufacturers to fit the (mis)conception that the lower the number the better the grip. Just slap a low number on a mediocre tire and ***Poof*** it's a performance tire! Test results will tell more. Really sticky tires will have lower TWs but the reverse ain't always true.
-- Chuck
-- Chuck
After reading the stickies, the thing is that both the AP1 with OEM 16s and AP2 with OEM 17s on OEM tires had a much higher ratio rear to front tire tread contact widths. But those tires are not available any more. Looking at the following ratios (front vs rear tires and vice versa), it seems that the 215/255 Conti gives you the highest rubber ratio at the back, though there's a 0.4 inch difference in height which might be visible. The math says the square setup will increase oversteer (too much traction on the front) and reduce steering feel, not looking to do that.
Right now, I'm running Continental DSWs on 16s 205/225 with a tread of 6.7" / 7.4" (r/f=1.104 or f/r=0.905), which is not right. The original AP1 tires were 6.9"/8.4" (r/f= 1.217 or f/r=0.821). The AP2s OEM tires had 6.7"/9.0" tread width which results in r/f= 1.343 or f/r=0.744.
Continental vs Bridgestone S-O4s Tread Widths
215/245 Bridgestone S-04: 7.7" f / 9" r tread width = 1.168 r/f (or 0.855 f/r) DIAMETER 24.7" both
215/245 Continental Extremecontact Sport: 7.3" f / 8.6" r tread width = 1.178 r/f (or 0.848 f/r) DIAMETER 24.6 " f / 24.7" r
215/255 Bridgestone S-04: 7.7" f / 9.2" r tread width = 1.194 r/f (or 0.837 f/r) DIAMETER 24.7" f / 25" r
215/255 Continental Extremecontact Sport: 7.3" f / 8.8" r tread width = 1.205 r/f (or 0.829 fr) DIAMETER 24.6" f / 25.0" r
225/255 Bridgestone S-04: 8.1" f / 9.2" r tread width = 1.130 r/f (or 0.880 f/r) DIAMETER 25" both
225/255 Continental Extremecontact Sport: 7.6" f /8.8" r tread width = 1.157 ( or 0.863 f/r) DIAMETER 25" both
I'm glad you like your setup. That is what really matters. FYI though, its a misconception that matching the CR stock sizes should choose 215/255. Yes, that is the sizes used with the oem RE070. But the specs for physical dimensions of those tires more closely match ap2 215/245 for most other tires.
Site Moderator
