buying used RE71R's, i could use some help!
Old 08-23-2017, 10:28 PM
Mugen_is_best's Avatar
Heat cycled at an autocross?!
Even if that were likely....what does "20 runs"? Or whatever even mean?
Its like saying I have some tires that have driven 75 dinosaur fields. For 85 foot years per cabbage.
75 dinosaur fields, for 85 foot years per cabbage? Sounds too old and worn
Old 08-23-2017, 10:34 PM
s2000Junky's Avatar
Petrified for sure
Old 08-24-2017, 03:02 AM
Chuck S's Avatar
Received 1,128 Likes on 991 Posts
16" wheels for auto cross?! I'd expect lots of tire squirm vs 17" wheels and lower profile tires.
-- Chuck
Old 08-24-2017, 04:51 AM
Conedodger's Avatar
Originally Posted by yamaha6611
yeah, thats kinda where i was at, actually thats what i offered... originally he wants $500 for the set. i offered 350 he said 450 i said ill call him back
Split the difference at $400 and call it a day.
Old 08-24-2017, 05:02 AM
engifineer's Avatar
Received 1,187 Likes on 921 Posts
Actually, you can kinda use runs as a measure in this case. It is a rough measure, but not terrible.
But more important is looking at the tires. If the center rib is worn down to the base rubber on either side (one side wears much faster on the center rib) then they are almost done. If the center rib still has some good rubber on both sides of it, and the shoulder tread is still running to the edge of the tire and is not almost gone, then there is likely some useful life in them. I still would not pay more than you are talking about in that case.
RE-71Rs by the way work just as good flipped. So if you get a set, make sure to flip them before one side of the center rib wears to the base rubber to maximize life. I have been through a few sets and most of us find that is a good measure of when to flip them.
Old 08-24-2017, 05:54 AM
j0oftheworld's Avatar
I just picked up 3 barely used 17" re71r for $100 if that helps..
I treat it like this, he has junk in his garage he doesn't want and you're paying him to take it away!
With my first s2k I bought a set of AP1 wheels (pc black) with Azenis for $400 as autox only wheels. Perfect for stock class or ST w. cheap tire options.
Old 08-24-2017, 09:17 AM
B serious's Avatar
Received 1,239 Likes on 940 Posts
Wear slows way down after 17 brontosauruses tho
Old 08-24-2017, 09:19 AM
B serious's Avatar
This is reasonable. The runs cannot be used as a determining factor...but maybe some sort of reference value.
Taking a look at them is needed. Opinions here are based on blind "wisdom".
And they're fast down to the cords. I doubt they cycled out from being driven in a parking lot for 50-60 second stints.
Old 08-24-2017, 11:04 AM
yamaha6611's Avatar
thanks for all the responses guys!!
Old 08-24-2017, 11:41 AM
Site Moderator
Manga_Spawn's Avatar
Um what wheels are they on? OEM AP1 rears? I never saw that mentioned.
kchandra
04-05-2012 10:58 AM
8kGoodENuff
08-26-2006 06:20 AM
ChrisfromRI
02-21-2004 09:37 PM
CrankyDBA
10-24-2003 06:40 PM
NewR
04-02-2002 12:18 PM
Quick Reply: buying used RE71R's, i could use some help!
