camber questions
camber questions
So i've decided to add some negative camber to both my front and rear wheel. I have a my08 and i was wondering if i can go up to -3.0 on the stock camber?
Originally Posted by s2k dre' date='Jan 26 2009, 03:55 AM
u should be able to! im runnin -3.5 in the rear, it doesnt matter how low u are, theres room for negative in the adjusters.
Am i way off here?
Originally Posted by Nabu' date='Jan 27 2009, 12:42 AM
If was under the impression that by using a stock suspension/springs combo we could only give as much as 1.7-2.0 in the front and 1.9-2.2 (?) in the rear. (numbers are not absolute but the range is somewhere around there)
Am i way off here?
Am i way off here?
Originally Posted by THESPY' date='Jan 27 2009, 09:08 PM
IIRC thats if the car is at stock height. When you lower it geometry changes and you can add more camber
My comment was mostly about s2k dre's post about being able to -3.0 camber on stock suspension.
