Can You Put Wheel Weights on the Inside of Wheel Spokes ?
The only reason that weigjts shouldn't go spokes is they will be much likely to get flung off the wheel. When they are on the barrel, 'centrifugal' force holds them in place.
But a better idea than on the spokes is to simply place them out of line with caliper. Say, closer to wheel centerline.
The balance machine tells operator where to place the weights. Inner, outer, and at what degree on the wheel (between 0 and 360 dregrees of rotation). But the only consequence of putting the weights in a slightly different spot is it will take a few more spims to get it to zero out.
Each new spin starts fresh. It doesn't remember where it told you to put the weights last time or know if you ignored it. So when you put weights close, but not exactly spot on, the next spin will be better, but not as betfer as if you put them spot on.
So all they gotta do is mark off the no fly zone on the wheel where they shouldn't put weight, and then just not put them there. Put them a little off of that spot to stay out of no mans land. It'll take a couple more spins and a little more weight, but it'll balance.
+1 on the spin tire 180 on rim thing. Whenever the machine asks for an unreasonable amount of weight, that should be first thing done.
Just to clarify, you don't want to put the weights on the spoke because they would fly off (that's probably part of it), it's because of the moment of inertia, putting them on the spokes would change the balance significantly, because they would be at a shorter radius than the weights on the barrel, they would need to add a significant amount of weights to make up for this.
^ thanks guys for all of the replies. I think I have the issue resolved with the weights moved away from the outer edge a bit. As the inside barrel is tapered the weights moved inwards has given me more clearance. As long as the balance is good I should have it working fine.
