Effect of front camber while turning?
When I am cornering very hard (hard enough to get pulled over if a cop saw me), and a hit a bump mid corner, there is only mild rubbing. If a little bit of camber could fix this I might do it. But I am not modifying my fenders.
My coilovers are adjustable and I can just raise the ride height up a little bit to avoid rubbing. This is not the "cool" thing to do, but it would be effective. I could also install stronger anti-sway bars, which would probably be a decent idea anyway.
When I am cornering very hard (hard enough to get pulled over if a cop saw me), and a hit a bump mid corner, there is only mild rubbing. If a little bit of camber could fix this I might do it. But I am not modifying my fenders.My coilovers are adjustable and I can just raise the ride height up a little bit to avoid rubbing. This is not the "cool" thing to do, but it would be effective. I could also install stronger anti-sway bars, which would probably be a decent idea anyway.
I think what I'll do in the short term is raise the car a tad... 1/4" should do. Rolling the fronts will NOT prevent tire/fender contact while cornering hard. The only thing it will prevent is the tire from grabbing the inner fender lip. I get that, and I agree it's important. Even if you completely eliminate that lip via rolling you still have to contend with the outside of the fender - which obviously doesn't go anywhere when you roll the inside lip.
The basic problem is that the car is too low for the amount of sway you are seeing while cornering. You can either raise the height, or reduce sway. Both should have the same effect.
Site Moderator
Whatever you say. Clearly you know best in this even though I run much more aggressive front wheels than you and I have no issues with rubbing when turning. What you are rubbing on is the fender liner which gets trimmed slightly when you roll the fenders. Then the lip of the fender and the fender liner are out of the way. Finally your suspension shouldn't have enough compression for the tire to contact the outter most lip of the fender.
This is what happens to front fenders once the liner is gone and the tire can grab that lip.
If what I'm saying is completely wrong, let me know.
If you have enough suspension compression such that you are risking grabbing the inner fender lip, then you have enough compression to also make contact with the outside fender as well, since they are essentially level with each other. You mention yourself that your setup should not allow this.
Theoretically you could tear up your fenders on a completely stock setup if you had enough suspension compression to make fender contact. The real problem here is low ride height and lack of suspension stiffness, not wheel offset.
You can theorize until the cows come home, but the bottom line is experience trumps theory on this topic. You've received solid and unanimous feedback from a handful of guys with first hand experience. It would be silly and costly to ignore the help these guys have given. Anyhow, I guess we will see you posting HERE in the future.
Look guys, I'm not looking to insult anyone here. I appreciate the feedback. What is frustrating though is that no one seems want to directly counter the things I'm suggesting. If I'm wrong, I want to be told why I'm wrong so I can better understand how things work.
s2000Junky... looking at your avatar for instance. When you're turning can you debate the fact that your tire is going to hit your fender if the wheel gets compressed more than about an inch? Rolling the front fender would only give you clearance equal to the thickness of the fender liner (plus fender plugs).
Next, dialing in the appropriate camber and ride height is a crucial aspect in fitment on aggressive offset wheels, plus more negative camber up front performs better if you like to push your car on the track or mountains. You never told us what your camber was, but I assume it is conservative? Pulling in the top of the tire from additional negative camber does give you added clearance under compression in a strait line and when the wheels are turned. Another aspect in this is not bashing into uneven driveways with your wheels turned at full lock, this is a sure way to make contact with your fender, so learning the set up leeway on your car and altering your driving technique when entering and exiting off camber driveways is good practice. You may want to jack up a corner of your car to compress the front wheels and see exactly where your front wheels may be contacting the fender, doing this wile stationery is risk free and will let you see what you need to alter. But no matter what you alter, I highly recommend you roll the front fenders to save them.
And no they don’t hit, because I have the appropriate height/wheel alignment and sidewall profile with rolled and pulled fenders. If I go off a jump and land with my front wheels turned then yes they probably would. But jumping my car with my wheels turned isnt part of the driving technique I employ with this car.
Bringing this back from 4 years of dead lol but I need help. I decided too lower my S2000 another half an inch all the way around too get it exactly where I want it. From the floor too the fender measures 24 and a half inches in the rear and 24in in the front as I like the front a little lower than the rear. So my alignment specs are -1.7 in the front and -2.7 in the rear, which I'm not really worried about the rear cause it doesn't rub. but when I turn in the front my tire touches the fender lip. My fenders are rolled, Help would gladly be appreciated, I just want the abiltity of being able too turn my car all the way without my fender getting f'd up. If you are going to give me alignment specs, please give me alignment specs best for straight line speed as I don't track my car. I will eventually boost the car and just do straight line races. Thanks
