Fitment with rolled fenders and tab relocate?
I have a 2005 s2000. So I've read many threads and gotten advice from reddit and Facebook and was looking to see if anyone here has a different opinion. Please be patient with me but I want to run these if possible
Looking at Gramlights 57dr 18x9+38 or Work emotions t7r similar size and same offset. 225 in the front and 255 in the back with stock suspension.
if I roll and tab relocate can I safely run these? If not how much fender work will I need? If its not practical ill just save up and do ASM rears and voltex front.
Hope this is the right place to put this.
Site Moderator
The fronts are going to be the issue. You can make the rear fit with roll tab relo and camber. The fronts are another story. I guess it really depends on what you consider fitting. If stretching a 225 lots of camber and pulled fenders they have at it.
I also saw that you put your specs in another thread. I was actually looking at possibly doing ASM rears and maybe flares that add 30mm in the front. Which is similar to your build I guess? Could these with the specs? 18x10.5+38 in the rear and 18x9.5+38?
Site Moderator
The issue with the front is there is a lot less space and since the wheel turns it is much easier for there to be contact with the fender.
Yeah with the wider fenders you could do that fitment. I ran my 17x10 +35's in front with a 255 and they fit under my downforce +30mm fenders. The rear you will likely need a little more camber but nothing crazy.
Okay! One last question. So the front overfenders I was going to go with was the Industry garage 30mm fronts and from what I read people hate the fitment etc etc. If I decided to go Voltex front and ASM rear the voltex front advertises 25mm, would that change my choice that much with the sizes? What could I run realistically, I dont' want to be stupid with my fit. I still want the car to be functional if I decide to have fun with it. The offset I do want is at least mid to high +30s (gram lights or work emotions)
Also thank you for helping me out.
Site Moderator
The voltex fronts you should still be able to fit the same thing in front maybe a little more camber will be needed. I'd probably run a 245 in the front for that little extra space.
