Front Fender Rubbing
hey guys, my front passenger side tire is rubbing on the outside edge and im not sure what i can do besides raise the car up a little. its strange though cause the driver side is not rubbing. any suggestions?
thanks,
brian
thanks,
brian
Did you check all the clips? Maybe some are broken and the fender liner is sagging and that is causing that side to rub. The only other thing I can think of is the suspension may be wearing out, or your coil-overs are not all at the same height?
BTW did you ever sell your other car?
no havent sold it yet. know anyone that needs a 2002 civic? oh and thanks for the referal to E-autosports. william hooked me up with the rear fender roll and bolt relocation.
out of all the people i know who rub, its always the passenger side. you can bend the tab back a little bit (i did that and it fixed my rubbing) or you can always add a bit more negative camber to see if it will clear.
btw, if u want to trade still lmk!
Originally Posted by captnplnet,Apr 17 2007, 08:58 AM
can you just remove the liner or will this cause other issues.
No problem with the referral. William is a great guy
im still debating on the trade....decisions are difficult. thanks
Originally Posted by captnplnet,Apr 17 2007, 09:45 AM
i will have to look and see what tab your talking about cause im not sure. but once i can figure it out i will give it a try. your not talking about a part of the fender right? its like a plastic/metal tab something would hook into?
oh and about running without the fender lining, some people say the rocks that fling up can cause little dimples to appear on your fender.
TJ
Originally Posted by silentdancer,Apr 17 2007, 10:09 AM
its a little plastic clip that holds the fenderlining onto the fender. i took a hammer and bent mine back a little bit.
TJ
TJ
Keith P
03-29-2014 05:46 AM
nos4you
08-16-2011 06:24 AM
GHS2K
06-06-2004 02:50 PM
