Help! How can I make this work?
I've rolled the rear fenders, not really rolled the fronts. I don't want to pull any fenders.....
Can I make this work just by camber??? I don't want to "get by" either..I want to be able to track the car and not worry about hitting a fender during hard cornering...if it's not possible, then I'll just forget it. thanks.
I'm running 17x8 +38 front 17x9 +40 Volk CE28's.
I needed a full roll front and rear and -2 front -3 rear camber to fit the wheels with 215/245 Star Specs, but I have no rubbing whatsoever. Hope that helps.
On the rears you'll need a good roll, relocate the tabs & run 235/40/17. 245/40/17 is huge IMO. I have 215/45/17 upfront on x8s & that works much better then 225s. Then again it depends how low you are. I'm completely tucked with no wheel gaps. Some people will tell you it'll work but they still have 1/2 inch gap. I'm also -2 degress in the back. GL with your setup.
