Ideal camber joint for fender clearance
Did some searching but couldn’t find a straight answer. If you came across a thread that covers this topic, please share link. If the main goal is to gain fender clearance at the front without too much negative camber, what would be the most ideal option, SPC Ball Joint, lower offset ball joint, or offset UCA bushings? Thanks.
Site Moderator
Hm ok. I would probably got with the +51 for that little bit of extra clearance. I don't think you should need any of the aftermarket camber joints to get the camber you will need. OEM has a good amount of adjustability. I have heard good things about the offset bushing though I haven't used them.
Former Sponsor
It's more fender friendly to pull the top of the wheel in rather than to push the bottom of the wheel out. Look into SPC Ball joints (I've got them on sale) Or offset delrin bushings.
