Go Back  S2KI Honda S2000 Forums > Special Interest > Wheels and Tires by The Tire Rack
Reload this Page >
More confused the more I read. Can I get your opinion on this wheel setup?
Notices
Wheels and Tires by The Tire Rack Discussion about wheels and tires for the S2000.
Old 03-09-2019, 11:31 PM
dc2-2-ap1's Avatar
Factory widths are fine with those specs (215/40/18 & 245/35/18). That will give a very good look. Those sizes will get you as close to flush with the fenders without modifications as you can get. You will rub if you go wider tire in the rear. My track wheels are 17x8.5+49 and they are fine with a 245/40/17 tire (no modifications in the rear).
dc2-2-ap1 is offline
Old 03-11-2019, 04:31 AM
Carbon Blue's Avatar
interested in what kind of track wheels you have and what you run in the front? ssr type c?
Carbon Blue is offline
Old 03-13-2019, 08:35 PM
dc2-2-ap1's Avatar
yes, my track set is 17x8.5+49 square with 245/40/17 (f & r). I also have a street set that have made a few track appearances, which are 17x9+55 (f) & 17x9.5+65 (r) with a 255/40/17 square setup on those. Both sets are SSR Type C RS. Only reason the skinnier setup is the track setup is because the paint isn't the best. I will eventually repainted them and use the wider set for track.
Old 03-14-2019, 04:51 AM
fastb4ck's Avatar
Advan seems to be the one of the only companies that makes proper s2000 sizes
Get some 17x8 +54 fronts and 17x9 +63 rears
fastb4ck is offline
Old 03-14-2019, 06:52 AM
rare set of wheels and sizes! Wish I found those..you wouldnt happen to know if they have any clearance to fit a bbk would you? Are your fronts rolled to fit the 245s?
Old 03-15-2019, 08:53 AM
dc2-2-ap1's Avatar
I believe the 17x8.5+49 and 17x9+55 both will. They both clear Spoon calipers, but I haven't tried them with other kits that generally space the caliper farther out. I only trimmed the fender liner and pushed the fender liner tabs up. No actual roll or change in exterior fender dimensions. I did that originally for the 9+55.
Old 03-15-2019, 08:58 AM
dc2-2-ap1's Avatar
Those are good sized.
The list of manufacturers used to be a lot longer. Volk, Advan, Enkei are some of the only ones that still make high offset wheels, Work and SSR used to make high offset, but they have phased them out of production.
ajracing
10-26-2015 03:34 AM
frodier
13
08-08-2014 04:17 AM
JustinC
18
07-10-2012 06:38 PM
myclue
10-03-2010 07:07 PM
JerryX
03-17-2007 03:53 PM
Quick Reply: More confused the more I read. Can I get your opinion on this wheel setup?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
