mugen mf10 17x8 +45
Old 02-18-2018, 11:50 PM
jtun3d's Avatar
Default mugen mf10 17x8 +45
I am eyeing a set of 17x8 +45 mugen mf10s but i heard that these wont fit because the front hub is too big for the center bore of the this particular spec can anyone confirm? And if so is there any way I can make them fit?
Old 02-19-2018, 08:38 AM
Site Moderator
Manga_Spawn's Avatar
What is the center bore on them? You could run a small spacer or take them and have them bored out to fit.
Old 02-19-2018, 10:14 PM
jtun3d's Avatar
64.1 is the bore
Old 02-20-2018, 06:28 PM
Site Moderator
Yeah the S2000 front hub is 70.3. So you either need a 5mm spacer or bore out the wheel to match.
Old 02-20-2018, 08:05 PM
afzan's Avatar
fyi 17x8 is smaller than the rear oem ap2 wheels
Old 02-21-2018, 01:20 AM
jtun3d's Avatar
@manga_spawn if i use a 5mm spacer to make the rims fit will the wheel be sticking out at all?
Old 02-21-2018, 04:14 PM
Site Moderator
Yes it would make them a +40 so they would be pushed out more. Also as AZfan pointed out if you are also running these in the rear the width isn't ideal due to being narrower than the OEM ap2 sizes. Unless these are dirt cheap and you just have to have MF10's I would look for better fitting wheels.
Old 12-22-2018, 11:45 AM
whitedxi's Avatar
Link?
PizzaBoy
01-27-2014 01:27 AM
07BBS2K
02-19-2010 12:27 AM
GSU S2000
11-27-2005 06:42 AM
goowattjuy
11-14-2005 04:45 PM
Quick Reply: mugen mf10 17x8 +45
