PF01SS Squared Setup
I really like the look of the SS with the bigger lip.
This being a 100% street/weekend car. I was thinking of going, Front 245/40/17 & Rear 255/40/17 Would that setup be fine on a 100% stock car, or would I still run into issues? If so I will go with the staggered setup. Thanks for the help. |
I run Front 245/40/17 & Rear 255/40/17 on a street car w/ no issues. Wheels size is 17x9 +61. Next time I'll do 255 square.
Are you lowered at all. Im thinking at some point a may go with a slight drop.
The 17x9 +60 can work with stock fenders. i still got an occasional rub in the front when i wasnt super careful going into driveways(with a 255/40 and lowered about 0.5-1 inch). So i ended up rolling the fenders to be safe. I have the 17x9 +48 in the rear and that required a roll and tab relocation.
I got 245 all 4 with 17x9 +48. The rear is flush really nice with the body. The front is poking out a little. Next set I'll go 235 in the front or get a pair of 17x8 or 17x9 +60.
My car has about 1" drop. I have to roll all 4 corners. |
Originally Posted by zpeed
(Post 24522232)
Originally Posted by brc80
(Post 24522358)
When you say the front is poking out do you mean the tire or the wheel?
I'm on 17x9 +63 TRMotorsports with 255/40r17 all around. Lowered on Fortune 500 coilovers. No rub.
Yeah +60 range offset works on stock fenders up front if not lowered too crazy, but you get into the +48 you are going to have issues and need to roll your fenders. They will stick out, certainly if you are running near stock camber alignment.
(Post 24521630)
