PF01SS Squared Setup
Old 12-01-2018, 10:01 PM
  #51
s2000Junky's Avatar
Originally Posted by DanielZan
im going with 235/255
I assume you mean the more common 235/45, so given that make sure the tire you choose has a good firm two ply sidewall construction to keep sidewall deflection down or you will be giving up some of the stock sharp turn in feeling.
Old 12-04-2018, 09:49 AM
  #52
DanielZan's Avatar
i meant 235 front 255 rear. Havent figured out the correct sizing
Old 12-04-2018, 09:54 AM
  #53
Site Moderator
Manga_Spawn's Avatar
235 is tough because there isn't really a correct sizing. If you do 235/40/17 then it is shorter than OEM diameter and 235/45/17 is taller. Personally either 225/45/17 or 245/40/17 is a better choice and I believe there is more tire choices due to either 235 size being an oddball size. For the rear 255/40/17 is the correct size.
Old 12-04-2018, 09:58 AM
  #54
s2000Junky's Avatar
Let me further clarify for you since you don't seem to be tracking with my reference. 235/45 or the shorter less common option of the 235/40 as two different options for front tires in 235 widths.. If you like the brand the 235/40 comes in then I would opt for this over the taller 45 series. If not, then I would move to the 245 front. Better to have a shorter sidewall tire up front if the pair is to be mismatched and not consistent with rear. But I would avoid the 235 all together and prefer to do 245/255.
Old 12-12-2018, 04:05 PM
  #55
brc80's Avatar
Wheels will be here next week. Anyone have any advice on alignment settings I should be using with my setup?
Thanks
Old 12-13-2018, 04:12 PM
  #56
brc80's Avatar
X-Mass came early wheels showed up today.
Old 12-13-2018, 04:50 PM
  #57
s2000Junky's Avatar
Springs too looks like
Old 12-13-2018, 08:04 PM
  #58
brc80's Avatar
Just need to settle on some tires and figure out some alignment specs.
Old 12-13-2018, 08:23 PM
  #59
brc80's Avatar
Also do I need hub centric rings? I dont see them in the box.
Old 12-14-2018, 09:23 AM
  #60
s2000Junky's Avatar
No not mandatory. I run without, many do.
Quick Reply: PF01SS Squared Setup
