Safe Tread Level for Rear Tires...
Old 12-21-2010, 04:15 AM
zeroptzero's Avatar
Received 3,370 Likes on 2,450 Posts
Default Safe Tread Level for Rear Tires...
I know for most passenger tires the recommended tire replacement level is no less than about 2/32nds. We've seen quite a few S2k's have spin out in the rain with much more tire than that, so what do most people on here use as a recommended replacement tread level ?. I just picked up a set of oem rims with Bridgestone tires that have between 6 & 7/32nds on the rear tires. They should last a while but I'd like to monitor them in the future and replace them before they get to a dangerous tread level. Can you guys recommend a safe tread replacement measurement ?. thanks for any replies on this.
Old 12-21-2010, 04:20 AM
deepbluejh's Avatar
Look for the wear bars. Once these are flush with the tread, then it's time to replace.
Note that some tires just aren't that great in the rain, so regardless of the tread level, hydroplaning is a risk.
Old 12-21-2010, 06:15 AM
camuman's Avatar
drive careful, but typically 2/32 on the insde of the tire and you should replace.
Old 12-21-2010, 06:34 AM
takeshi's Avatar
Definitely check the inners.
Old 12-21-2010, 09:39 AM
Gloffer's Avatar
If you find you've got more wear on the inside rear than the outside rear which is typical for an S2000, then just flip the tires on the rims, re-balance and you should be good for a few thousand more miles. IMO, you should do this when you've got more than 5/32s on the inside rear. Of course this works for the fronts too.
Old 12-21-2010, 09:47 AM
camuman's Avatar
quick thing, make sure your tires allow for flipping. some dont.
Old 12-21-2010, 09:53 AM
zeroptzero's Avatar
thanks for all of the replies. Thanks for the tip on measuring the inside tread, as the measurement varies across the width of the tread, I'll definitely keep that in mind.
cocogirl
12-10-2010 03:54 PM
senor_flojo
15
02-05-2010 08:03 AM
Cawdor
07-07-2008 01:59 PM
N10CITY
10-20-2006 05:45 PM
Formula
06-13-2005 06:34 AM
Quick Reply: Safe Tread Level for Rear Tires...
