Should I run max camber? And do I need a FSB? Square setup RS3's
I have always wanted to do the sqaure setup on my s2000. I bought ap2 rears and a 5mm spacer so they clear the from and I have 4 Rs3's. Im not slamming the car, I just want to clear the wheel gap. My question to you guys are is, for my alignment setup, do you guys recommend that I run camber? I do like taking turns agressively. And I track the car at least 5 times a summer. But keep in mind I am putting down a decent amount of power so im torn if I shouldn't or should run camber so I have all of the rubber touching the ground(I need it!) Its an ap2. For the guys running the sqaure setup, did you guys need to modify anything suspension wise?
most of the guys maxing out their camber are doing so because their wheels are agressive. they are dialing in the camber to avoid tire rubbing. with ap2 rears on the front is still not going to need any major changes in your alignment. i would recommend you run UK alignment specs or something similar.
zeroptzero
03-31-2016 06:09 PM
inspector tequila
04-03-2014 10:00 PM
DaveZuck
12-15-2011 12:01 PM
