Spacer w/ CE28n
Spacer w/ CE28n
I am looking to run a spacer with my CE28ns but I don't know if I should go with the 10mm or 15mm spacer. I was running work meister s1s that were 18x9.5 +63 with 265/35/18s. Now I am running CE28ns 17x9.0 +63 with 255 40/17s.
What is the highest I can go with out rubbing on the rear fender?
Thanks!
Thanks!
17x9+63 offset with a 255 rear tire and 15mm spacer is easy so long as his fenders are rolled. I would recommend the Kics spacer because they lock down your original wheel studs and are very well made.
Originally Posted by nevaland9,Apr 3 2008, 12:22 PM
with some rolling and light bumper cutting we get 17x9.5+38 all around super duper slammed too.
You gotta take your wheel off to check if it has clearance for the studs.
The og studs are about an inch so if you run a 10mm spacer your wheel needs to be able to clear another 16mm.
Just a heads up!
jim
Just a heads up!
jim
