Volk CE28N 18x8.5 +52 Square?
Old 02-12-2018, 09:26 AM
Drev77's Avatar
Default Volk CE28N 18x8.5 +52 Square?
So I've found a square set of Volk CE28N wheels for sale locally that I'm very interested in, but I have some concern with respect to fitment. I've done some searching and this size (18x8.5 +52 offset) is just outside of the fitment guide for the front of the car. Any opinions on whether this setup would be a good option and fit without any fender mods whatsoever? I'm 100% stock everything with no desire to lower/roll/pull/relocate. The tires on the set are in need of replacement and they are likely the wrong size as they were on a STI before. Suggestions on proper tire size would be helpful as well. Thanks in advance!
Old 02-12-2018, 09:51 AM
Site Moderator
Manga_Spawn's Avatar
At stock height it should be ok. If you lower the front will be an increased risk. As for tire sizes you have a few options. You could do a 225/40/18 front paired with either a 245/35/18 or 255/35/18 rear (Pretty sure the 255 would still fit the rear at stock height). Or you could run 245/35/18 all around. This may be risky on the front however even at stock height.
Old 02-12-2018, 10:22 AM
Drev77's Avatar
Thanks for the quick reply! Is this rim in a 18 inch size too large for the car...especially the front? I know that 17's are ideal. Maybe it would look funny sitting at stock height with a 18 inch set?
Old 02-12-2018, 01:29 PM
dc2-2-ap1's Avatar
18" is fine. I would go with 245/35/18 all around.
My track wheel setup is 17x8.5+49. I ran 245/40/17 and am lowered maybe 1.25" lower than factory. I do have my front fender liner tabs pushed up and the fender liner trimmed though (no change to outward line of fender). I did that for my 17x9+55 wheels (255/40/17) so I can't say for certain if it is needed.
Old 02-12-2018, 01:59 PM
Site Moderator
Derp. Totally missed the 18 thing so my tire sizes are off. 18's are fine on the car.
octechgeek
09-07-2008 12:16 AM
FormerH22a4
04-08-2007 07:00 PM
rsquadron
08-10-2005 03:46 AM
S2KDRIVER18
10-19-2003 04:49 PM
Raines48
09-12-2003 02:02 PM
Quick Reply: Volk CE28N 18x8.5 +52 Square?
