Tire selection for 17x9 +45 rpf1 STAR SPEC ZIII - S2KI Honda S2000 Forums
Wheels and Tires by The Tire Rack Discussion about wheels and tires for the S2000.
Old 02-13-2018, 06:23 AM
Default Tire selection for 17x9 +45 rpf1 STAR SPEC ZIII
whats up guys looking for some good info so I’ve come to the right place. I’m getting new bronze rpf1’s for my Suzuka ap1. I’m looking for good fitment all around I will be going star spec ziii’s to be released March 16th confirmed by tire rack. My question is for the front with slightly rolled fenders do I go 225/45 or 235/40. I will be on a 245/40 rear. I’m really not looking to do any pulling. If any one can shine some light or any pics Thank you in advance! I would like set up to be somewhat similar in tire diameter as far as appearance.
Nick2t1me is offline
Old 02-13-2018, 06:52 AM
TsukubaCody's Avatar
Bronze?
Eek.
I'd go 225 if you're afraid of pulling.
Sincerely,
Guy with 255/40 up front on 17x9 +45
TsukubaCody is online now
The Following User Says Thank You to TsukubaCody For This Useful Post:
Nick2t1me (02-13-2018)
Old 02-13-2018, 07:05 AM
235/40 are significantly (0.6") shorter than 225/45, might not be much if any worse for clearance, might have more clearance at a given ride height.
I'd probably go with the 235/40, but I'd rather have +50 or more offset...
ZDan is offline
The Following User Says Thank You to ZDan For This Useful Post:
Old 02-13-2018, 07:29 AM
Lol bronze I think looks alright with the Suzuka but each his own but thanks for the input and I was torn between black which makes the car dull out but again Suzuka is a PITA color
Old 02-13-2018, 07:36 AM
I agree Dan about what your saying I’m just note sure what would work better but I do think I might go with the 235 as it’s wider at 200+ $ a tire I definitely wanna try and get this right the first time
Old 02-13-2018, 08:12 AM
What ride height are you planning?
Must also consider tire height.
235/40 = 24.4"
245/40 = 24.7"
225/40 = 25.0"
Old 02-13-2018, 08:46 AM
You don't need to pull to clear the wider 255/40, you need a proper roll and greater than ~2* camber. I found the rear more annoying to get to not rub.
Chibo is online now
Old 02-13-2018, 08:50 AM
Site Moderator
Manga_Spawn's Avatar
245 or 255 all around. Fronts need a pull unless you run more camber like Chibo said. Relocating the rear tabs and rolling the fenders flat will stop the rear from rubbing.
Manga_Spawn is offline
Old 02-13-2018, 09:24 AM
s2000Junky's Avatar
Depends on what his ride height and camber will be is if he is going to need a pull or not on either a 245 or 255. 225 or 235 would be my suggestion if you want to shy away from the pulled look. 225 if you want to be consistent in sidewall height to the rear 255. But 235 with the shorter sidewall in my opinion looks good to. Your brake bias will move forward slightly with the 235, which is more stable at speed.
s2000Junky is online now
I'm running -2.4* of camber up front.
With 255/40/17 RT615K+ on 17x9 +45 RGIII.
I needed a pull.
It is subtle, but definitely there.
HawkeyeGeoff (02-13-2018)
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
