Tire Size
Your rear wheels at 8.5" wide could probably do 215 to 265 with the middle of that range being ideal.
Different tire makes/models may have different recommended wheel widths for a given size, so double-check that your wheels are in the recommended range for the specific tire you're buying.
Originally Posted by xveganxcowboyx' timestamp='1308013172' post='20679153
They will fit just fine. Wheels have a tire range that they can fit. Your 7.5" wheels could safely run anything from 205 to 245,
You're right, for some reason I thought AP2 fronts were 7.5, but apparently not. 8" is ideal for a 245, but they fit with only a small amount of bulge and a small loss of turn in on 7.5. As I said, the ranges I listed were ball park safe ranges, but the ideal is not to be at the extremes. For instance, the 7" wide front could safely run 235, but the trade off in loss of feedback is probably not worth it for most people over 225 or 215.
I agree with checking the wheel size range for any given tire type. Tire rack lists the wheel range under specs. It's a good place to verify appropriate sizes.
I just bought a used set of TE37
17x7.5 +48 & 17x8.5 +50 rubber on them currently is 215 and 255 and low on tread. I'm at stock height and wondering if I can fit 235 and 265?
Sent from my GS3 using Tapatalk 4 Beta
I have the same sizing but im running 225/45 and 255/40. Anything size bigger will increase the height and weight. Not worth it.
Former Sponsor
The other thing is even though Honda used 215/45R17 and 245/40R17 the tires were very different than other tires in the same sizes. The front tire they used was very narrow for the size and the rear was very wide. If you go with the 225/45R17 and 255/40R17 you are going to have about the same amount of stagger front to rear as what came on the car stock. With the advantage of more tire on the ground.
If I can help let me know.
