Tires 220tw and above
Im looking to do a global time attack event next year at RA in enthusiast class which has a tw limit of 220. Since Ive only used and researched 200tw and r-comp tires for autocross and track events, Im not really familiar with tires over 200tw besides what Ive skimmed on s2ki. Ive only used RS2v2 and NT01's on track and I know Im not going to be getting the same performance with tires of a lesser category. In peoples experience, what are good track tires that fit my requirements. The setup will be square 255 or 245 17's with aero. I was considering PSS's, Firehawk Indy 500 or the Zestino Gredge. Ive seen the positive reviews for the firehawks as well as the new Continentals. I am leaning towards the Firehawks since theyre cheap and Id like to wear a set down to feel them out but if anyone has positive experience with others, please chime in. Thanks!
Since the PSSs are discontinued, your best choice are Pilot Sport 2s, which are right at 220twr
Lowest treadwear rating of 220 or higher at Tire Rack appears to be the Bridgestone S-04 tire "rated" at 280. I know it's available in 245mm and 255mm. All the others I see there have higher numbers. Doesn't mean they're less efficient, just that they have different numbers. Tire testing is more important than a number on the sidewall. Your competitors have probably done this. Run what the winners run.
A low treadwear rating does not mean it has better grip and comparing between tire brands is not completely helpful as tire manufacturers assign a treadwear rating to each tire model as a comparison between tire models for a given brand. High performance tires typically wear faster than generic tires but since this is up to the manufacturer they can slap on any number they want. Easy to make a generic tire into a performance tire by putting a low treadwear number on the sidewall.
-- Chuck
-- Chuck
Afterfire (05-25-2017)
-- Chuck
-- Chuck
-- Chuck
-- Chuck
Hey RedCelica. Do you have experience with the PS2's? Im looking at TR's site and while it is an older review, they put the PS2's third behind the Goodyears and Continental DW's, which the Sport replaces and have been hailed as superior.. Im not taking that review as the final verdict though and Ill do more research on them. Thanks! I appreciate the feedback!
It's your clear choice IMO. To answer your question, no I've never run them, but the data shows the results.
DWs are crap on track, softer sidewall and not predictable (I'd pick them as a decent rain tire though)...note in that testing that PS2s achieved the fastest dry lap times: https://www.tirerack.com/tires/tests...y.jsp?ttid=140
Just as an aside, I dont see the PS2 achieving the fastest lap times in the graph you showed, but rather the Eagle F1's at 29.12. Maybe Im looking in the wrong place. But in all that data, the PS2's and DW's arent that far away from each other, and as you said, everyone reports the DW's as being bad on track.
Ah I was referring between the DWs and the PS2s...the Eagle's may be the best performer, but I didnt see them listed in a 255/40/17
