TPMS... What are my options
Have been trying to do as much research on this as possible, but it's hard to find info about TPMS stuff on the S2000. Talked to another member that said the "TPMS pipe bomb" doesn't work on the S2000. Not sure why, but that was what I was planning to do. If my OEM sensors don't fit the Prodrives I'll be putting on, I'll have to buy new sensors, go to the dealer to get them programmed, etc. A lot of money and time to keep a stupid light off. Thoughts?
Give my a few and I will help you out as I have a 08 s2000 and just went thru this. I'll make life easier for you.
I'm all ears. :)
would like to know as well!
i have CE28's on my 08. i think if the wheels are 1 piece, you should be ok, its the 2 piece wheels with 90 degree valve stems that cause problems
After a while I learned to forget that the light is on. Problem solved. It's not a big issue for me.
Well from research, it seems that if the light is triggered, the ECU disables VSA. I'd like to have a fully operating system.
Originally Posted by ungucpho
(Post 22165547)
Interesting...I've taken my car to the track twice and VSA still engaged.
Originally Posted by ryuken
(Post 22165585)
