TRyin gto work out if theses will fit (new to this)
Hi ive never fitter aftermarket wheels always stuck to oem, but I love theses and not sure if they will fit or not?
it will be going on a 2002 AP1
will theses just bolt on no issues or will I need to change the arches at all?
- Brand : Bola
- Model : CSR
- Width : 8J (Front) & 9J (Rear)
- Diameter : 18 Inch
- Bolt Pattern : Most 5 Stud Fitments
- Offset : ET25-45 (Front) & ET25-45 (Rear)
- Colour : Matt Bronze
- Style : 10 Spoke, Concave Rear
Former Sponsor
I think he meant the offset ranges from ET25 to ET45.
18x8 +45 should fit up front with a minor roll to bend teh tabs out of the way.
18x9 +45 with a 245 or 255 will fit in the rears with the fenders rolled flat. And tab relocated. 265 should still fit, but it will depend on how much camber you have and how low you are.
I have managed to fit a 265 square on a 18x9 +45, but it did require a slight pull.
k666sdb (07-11-2017)
the plan will be to add wider arches but I have and arch roller so that wont be much of an issue, I would just worried about it hitting the inner arch more.
+45 on front and rear will be fine with a roll.
Site Moderator
Yup +45 on both. Roll the fenders and relocate the rear tabs and they will fit. IMO there is no reason to use a 265 given that it is taller than OEM. 255 is more than wide enough for a 9 inch wide wheel.
