what size tires do i need?
Old 10-25-2010, 08:32 AM
Trent06's Avatar
Default what size tires do i need?
i have sbc rpf1's in 17x8 +45 front and 17x9 +45 rear. i do not want to roll fenders. according to the sticky, i am looking at 215/45 for the front and 245/40 for the rear. am i correct?
Old 10-25-2010, 10:05 AM
Euroflavor's Avatar
looks pretty reasonable. how much are you lowering yourself?
Old 10-25-2010, 11:07 AM
Trent06's Avatar
i am thinking about going with eibach pro springs
Old 10-25-2010, 03:36 PM
nigoape1's Avatar
why not 225/45/17 front and 245/40/17 rear?
Old 10-25-2010, 04:58 PM
Trent06's Avatar
im not sure i can run that wide of a tire without rubbing. i also dont want to roll my fenders.
Old 10-25-2010, 08:53 PM
'09S2K's Avatar
A 225/45 will have a taller sidewall than a 245/40... :/
A 215 on an 8" wheel will be stretched :/
Just get the proper tire sizes and make them fit. You spent the money for the wheels, now finish the job
Old 10-26-2010, 07:39 AM
Trent06's Avatar
what are you suggesting?
Old 10-26-2010, 08:13 AM
1nate7's Avatar
215 on a 8" wheel is hardly a stretch and is within the conservative manufacturer's recommended fitment. 215/45, 245/40 is your best chance, will still be close to rubbing in the rear. I'd recommend running UK spec alignment, -1 camber front and -2 rear.
Old 10-26-2010, 09:39 AM
evil MS3's Avatar
I rub the bumper tabs on the rear hitting dips at speed running the same exact setup. This past weekend a friend installed my Eibach pro-kit while I rolled the rear fenders and we trimmed the bumper/tab.
I havent had a chance to take it our since then(flat rear) but I'll let you know how it goes after that.
If you're going with the prokit you might want to consider rolling the fenders but you'll definitely need to trim the bumper and bumper tab.
Old 10-26-2010, 09:41 AM
evil MS3's Avatar
oh, and the front you can run a 225 with no worries. Go for it
Quick Reply: what size tires do i need?
