Wheel fitment
Old 04-30-2013, 05:48 PM
MSBx03's Avatar
Default Wheel fitment
So, I'm shopping for some wheels and I'm completely oblivious as to what off sets to get.
I want an agressive fitment, but I don't want to have to do ANY modding to the car to get them to fit.
I want to run a 17; thats about all I know.
So, I guess my questions is: What is the most agressive off set that I can run without modification?
Old 04-30-2013, 06:35 PM
ryuken's Avatar
There's a pinned section called Wheel Fitment Guide up top. It should help answer most of your questions.
Old 05-01-2013, 05:57 AM
1nate7's Avatar
You can't have both. You are basically stuck with stock fitment if you don't want to roll the fenders. You might be able to get away with offsets ~15mm more aggressive if you are still at stock ride height.
Old 05-01-2013, 06:42 AM
ZDan's Avatar
Don't fixate on OFFSET. Minimizing offset simply means minimizing the wheel and tire width you can run.
A 255-width tire on a 17x9" +50 offset wheel will have the wheel lip and outer tire surface at the same position as a 205-width tire on a 17x7" +25 offset wheel. SAME flushness. The differences are that the +25 offset setup gives less grip, looks ridiculous, has scrub radius issues, and reduces effective suspension stiffness (wheel rate).
Of course some will insist that the +25 offset setup is more "aggressive"...
Old 05-01-2013, 02:53 PM
MSBx03's Avatar
I think I'm just going to go with the OE AP2 fitment...
Old 05-01-2013, 04:44 PM
ZDan's Avatar
You could easily go with something like Enkei PF01 in 17x8 +50 front, 17x9 +60 rear with 225/45 and 255/40 tires, or 17x9 +60 all around with 245/40 front, 255/40 rear tires. Should fit without a problem with no mods.
Old 05-01-2013, 05:07 PM
FluKy15's Avatar
Putting a properly sized spacer on can make it look aggressive as well.
Old 05-07-2013, 03:32 PM
MSBx03's Avatar
Can't find those exact measurments.. would a 17x8+45 (F) and 17x9+45 (R) work without any stretching or tab relocations?
Old 05-07-2013, 03:39 PM
1nate7's Avatar
No. That rear will stick stick out 1" compared to stock.
Old 05-07-2013, 04:03 PM
ZDan's Avatar
You should be able to run stock AP2 sizes with those wheels: 215/45-17 front, 245/40-17 rear, with no mods. No promises though!
What 1nate7 said^^^, the outer wheel lip on the rears sticks out 1" further than a stock AP2 wheel. The outer edge of the tire tread, however, sticks out "only" 3/4" more than stock AP2.
Quick Reply: Wheel fitment
