Wheel Fitment Guide
#1421
Site Moderator
The BBK fitment will depend quite a bit on the wheel design not just the offset. With an added 25 mm fenders you have a lot of choices. I run 17x9 +43 in front and 17x10 +35 in the rear with Downforce front fenders and ASM rear overfenders. I have also run 17x10 +35 with a 255 all around on this setup and both fit over my brembo's. I would look at 17x10 wheels and keep the offset in the +35-45 range. You can fit a lower offset in the rear than the front in all cases. As for BBK clearance you have pick a specific wheel and specs and then find out the clearance.
#1424
#1426
I see on the Enkei chart this is the closest to S2000 spec for the new Enkei NT03-RR
17x7.5 +50 Front
17x9.0 +63 Rear
This spec can fit with 225/255 without any modification to fenders.
#1427
Site Moderator
Where are you getting those sizes from? According to the Enkei chart they dont make those sizes.
17x7.5 +50 Front
17x9.0 +63 Rear
17x7.5 +50 Front
17x9.0 +63 Rear
#1430
Yeah that spec will have to be special ordered. Special Order Enkeis take around 2-3 months to come into the states. Let me know and I can order you a set. Only need 50% down.
